- 11 Dec 2005
- Cheshire
The Cosmos II Ultra tower case accomodates this behemoth watercooling solution and operates in near silence thanks to the intergrated fan controller paired with Scythe Gentle Typoon 120mm fans.
For the hardcore among us, we offer a Crossfire upgrade to double your firepower, pair this with the optional sound card upgrade to enjoy crystal clear HD audio courtesy of the Asus D2X Sound card.
OcUK Tech Lab - "Ultima 9700i Blade" Intel Core i7 3930K 4.20GHz Six Core System @ £2,914.98 inc VAT
The "Ultima 9700i Blade" is designed and engineered by the OcUK Tech Labs team from the ground up. Featuring an Intel Core i7 3930K 3.20GHz processor overclocked and guaranteed to a blistering 4.20GHz. With a full custom watercooling loop pre-installed the "Ultima 9700i Blade" features quiet operation with ultra low temperatures allowing the processer to be overclocked to the highest standard. With a grand total of 3 radiators, cooling performance is unsurpassed. Slice through the latest games with a combination of SSD speed and the raw power of the Radeon HD 7970.
Why Should You Buy This System?
- The 4.20GHz overclock ensures lightning fast processing speeds
- Custom Watercooling for ultimate performance
- Featuring DX11 cinematic graphics
- 2133MHz RAM speed for blistering performance
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Cooler Master Cosmos II Ultra Tower Gaming Case
- Power Supply: OCZ ZX 1000W PSU
- CPU: Intel Core i7 3930K 3.20GHz @ 4.20GHz
- Motherboard: Gigabyte X79-UD3 Intel X79 Chipset (Socket 1155) DDR3 Motherboard
- RAM: G.Skill RipJawsZ 16GB DDR3 2133MHz Quad Channel Kit
- Hard Drive: OCZ Vertex 3 60GB SSD & 1TB HDD
- Graphics Card: Watercooled ATI Radeon HD 7970 3072MB GDDR5
- Sound: 7.1 Channel Sound On-Board (Upgrade available)
- Optical Drive: Samsung SH-B123L/RSBP 12x BluRay ROM / DVDRW DL & RAM Lightscribe SATA-II Optical Drive - Black
- Cables: BitFenix Alchemy Sleeved Cables - Silver
Watercooling Specification
- Radiator: XSPC EX360 Radiator, XSPC EX120 Radiator & Hardware Labs SR-1 240 Radiator
- Pump: Alpahcool Laing D5 Vario w/Alphacool HF D5 Top - Black Acetal
- Reservoir: EK Multi Option 250 Reservoir - Basic
- CPU Block: EK Supreme HF - Nickel Acetal
- GFX Block: EK FC-7970 Full Cover - Nickel Acetal & Backplate - Black
- Fittings: x14 OcUK Fatboy 7/16" Barbs - Nickel, x2 EK 90 PSC Rotary Fittings, x3 EK 45 PSC Rotary Fittings
- Tubing: x3 XSPC Tubing - 1m (Total 3 metres)
- Fans: x6 Scythe Gentle Typhoon 1850rpm 120mm Fan
- Fluid: Mayhems Aurora Fluid - Supernova Clear
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Providing the latest in gaming technology and performance combined with second to none cooling. The "Ultima 9700i Blade" is our coolest system yet!
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £2,914.98 inc VAT.
ORDER NOW
More pics
Service Package
ORDER NOW
More pics
