OcUK Titan Exodus, overclocking settings for i5 760 2.80GHz @4.00GHz
1 Aug 2013
Nottingham, UK
Hello!
I have a "Titan Exodus" pre-built system from OcUK, purchased May 2010:
  • Intel Core i5 760 2.80GHz overclocked to 4.00GHz
  • Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
  • Asus P7P55-M Intel P55 (Socket 1156) DDR3 Motherboard (P7P55D-E LX specifically)
I've recently upgraded the BIOS from the original version (0201) to the latest (1701).
Alas, I didn't note down the overclocking settings, and attempting to re-apply the saved "ocuk" O.C. Profile simply gives a "Status: Profile 1 item is not match" error message.
I've attempted to do some overclocking myself, but I can't get it to go up to the previous 4GHz.
Would some kind soul be kind enough to let me know what their BIOS Ai Tweaker settings are that let them run at 4GHz? CPU Ratio, BCLK Freq, IMC, CPU voltage, etc?
Thanks!
--M.
I'm sure if you ring OcuK and tell them what you have done they will walk you through
the overclocking settings that you need as they are really good like that and there
customer service is the best I have ever seen.
Hi Scotsdragon and Shadz,
Thanks for the replies!
I've also already contacted OcUK support via their WebNote system, but they say they unfortunately don't have details of the configs from 2010, and suggested I ask on the forums instead.
I've posted another message in the Overclocking section, please send any further replies there: http://forums.overclockers.co.uk/showthread.php?p=24706242
Thanks,
M.
