** OcUK UK FIRST TO PRE-ORDER - EK SR-X Blocks **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
I know it wont apply to 99% of you, but we are listing waterblocks for the superb new SR-X board from EVGA
Stock will be here in the next week and currently OcUK is the onlyu reseller listing them.
EK-FB KIT SR-X - Nickel @ £109.98 inc VAT
EK-FB KIT SR-X full-board water block kit is a complete liquid cooling solution for EVGA Classified SR-X (270-SE-W888) motherboard. The water blocks directly cools Intel C606 southbridge (PCH), PLX PEX8784 PCIe lane splitter controller and power regulation (VRM / MOSFETs) module of both CPUs. Please note this water block cools exactly as much heat generating components as EVGA factory cooling solution. It is medium-high to high flow water block that can be easily used with systems using weaker water pumps.
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality satin finish acrylic material. The sealing is performed by quality rubber gaskets.
Water block is mounted with enclosed M2.5x4 DIN7985 screws and PVC washers. The 2.1mm nickel plated brass screw-in standoffs are already preinstalled and allow for easy installation.
Enclosed thermal pad is used on voltage regulator modules to improve cooling performance of the waterblock. On the southbridge and PCIe lane splitter chip please use any electrically non-conductive thermal grease, e.g. Arctic Cooling MX-4.
Enclosed:
- 3 x water blocks (2x MOSFET & SB)
- mounting mechanism
- thermal pads
Fittings are optional not enclosed! Six fittings are needed to make this waterblock to operate properly. All EK-PSC fittings are compatible with this water block!
Made in Slovenia - Europe!
Please note:
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
- Fittings with G1/4 thread longer than 5mm are not supported!
Only £109.98 inc VAT.
ORDER NOW
EK-FB KIT SR-X - Acetal+Nickel @ £109.98 inc VAT
Base of the waterblock is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber gaskets.
Enclosed:
- thermal pads
Please note:
ORDER NOW
