**OcUK ULTRANOTE RANGE: NEARLY AS SMALL AS A ULTRABOOK, MORE POWERFUL & COST LESS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Were now building our equivalent to Ultrabooks but better, 14" in size and only marginal thicker than an Ultrabook, our UltraNote's allow the use of much faster CPU's with HD 4000 graphics and also come with an Optical DVD-RW drive too. Even better they start from £500, making them much better value for money than Ultrabooks.
You can either custom configure your own here:-
OcUK Professional W540 UltraNote 14" LED HD Intel Processor, DDR3, SSD / HDD, Intel HD 4000 Graphics - Windows @ £500.00 inc VAT
This Professional W540 is an user-customisable Laptop which means you spec it and we build it and can delivery as fast as next day when FAST TRACK service is selected. Built around an UltraNote W540 chassis which is very similar in size dimensions to an Ultrabook though marginally larger as it also features an optical drive. Even more the marginal size increase means far superior performance from the Core i5 processor with dual core plus hyperthreading. The biggest bonus is the inclusion of Intel HD 4000 graphics compared to an Ultrabooks HD 3000, this means 3D graphics performance is vastly superior.
So enjoy superb performance from this very small, compact and stylish OcUK Professional W540 UltraNote. Ideal for any professional user who travels a lot and has to work on the move, but at the same time can take a break and play games as well.
We also construct using using super-fast Plextor mSATA SSD's, this means incredible upto 500MB/s read performance and upto 340MB/s write performance along with 80,000 IOPS. More importantly it means you can still add a further 2.5" storage drive should you wish to do so.
You can now have us build you your ideal specification of UltraNote and get it delivered in no time at all, what are you waiting for?
Specification:-
- Operating System: Windows 8 64-Bit
- Display: 14.0" SuperBright LED HD Display (1366x768 Resolution)
- Graphics: Intel HD 4000
- Storage: Select from drop downs
- Secondary Storage: Select from drop downs
- Optical: DVD-RW Drive
- HD Audio
- Mic Noise Suppression
- 2 megapixel Webcam
- Processor: Select from drop downs
- Physical Specification: 340mm x 241mm x 11mm ~ 25.4mm (2.15kg with battery)
- Memory: Select from drop downs
- Main Chipset: Intel
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- Intel Centrino Wireless N-2230
- Bluetooth Support
- 1x HDMI Port
- 1x VGA Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- Kensington Lock: YES
- 6 Cell Smart Lithium-ION Battery
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Incredible on the move portability and performance along with small form factor.
ORDER NOW
Or soon we shall have the two below in stock available for collection or next day delivery:-
OcUK Express W540 UltraNote 14" LED HD Intel i3-3120M, 4GB 1600MHz, 128GB SSD, HD 4000 Graphics - Windows 8 @ £559.99 inc VAT
This Express W540 is an Express Laptop which means it is in stock and ready for collection or next day delivery. Built around an UltraNote W540 chassis which is very similar in size dimensions to an Ultrabook though marginally larger as it also features an optical drive. Even more the marginal size increase means far superior performance from the Core i5 processor with dual core plus hyperthreading. The biggest bonus is the inclusion of Intel HD 4000 graphics compared to an Ultrabooks HD 3000, this means 3D graphics performance is vastly superior.
So enjoy superb performance from this very small, compact and stylish OcUK Express W540 UltraNote. Ideal for any professional user who travels a lot and has to work on the move, but at the same time can take a break and play games as well.
This PLUS edition is our highest specification UltraNote in the Express range, it has 8GB of 1600MHz memory, so you'll never run out of memory so working on spreadsheets, charts, documents or even photography is an absolute breeze. The 120GB SSD ensures no matter what your doing, it shall be instant, to load Windows 8 from a cold start takes less than 10s and with 120GB you've more than enough space for Windows, all your office applications, a few games, photos, music and more.
Specification:-
- Storage: Plextor M5 mSATA Series 128GB SSD Primary Boot Drive
- Secondary Storage: N/A (room for 1x 2.5" drive, we can fit any 2.5" from our catalogue upon request)
- HD Audio
- Processor: Intel® Core™ i3 3120M 2.50GHz Processor
- Memory: 4GB DDR3 System Memory at 1333MHz (2GB x 2)
- Bluetooth Support
- 1x HDMI Port
- 1x VGA Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Only £559.99 inc VAT.
ORDER NOW
OcUK Express W540 UltraNote PLUS 14" LED HD Intel i5-3210M, 8GB 1600MHz, 128GB SSD, HD 4000 Graphics - Windows 8 @ £649.99 inc VAT
Specification:-
- HD Audio
- Processor: Intel® Core™ i5 3210M 2.50GHz Processor (3.10GHz Turbo)!
- Memory: 8GB DDR3 System Memory at 1600MHz (4GB x 2)
- Bluetooth Support
- 1x HDMI Port
- 1x VGA Port
- 2x USB3.0 Ports
- 1x USB2.0 Port
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
Only £649.99 inc VAT.
ORDER NOW
We shall be adding more CPU and ODD options to our customisable model over the next week as well. :)
Nice Gibbo! The screen resolution is too low though, can you get any in with higher resolution panels?
Yes I have a 15.6" ultra slim model coming very soon which is 1920x1080 and is wait for it, also an IPS panel. :D
Shall be approx £100 more for same spec as ones above and its stunning, only weighing 50grams more. :)
It's a shame you can't target more uni students easily. What a perfect system ;)
£100 more is nothing for a machine of that spec :)
They shall be online in a few days, takes me quite a lot of time to phase in new laptops, as I build the test mules myself and test them. Then I do all the online content and configuration work, which all takes time.
But shall be getting on with it next week for sure, so they will be online soon. :)
On a different subject I've got some new crazy ones here which have SLI and Crossfire, they are a bit bigger than these UltraNotes though, but the ultimate in gaming. ;)
Quit your complaining! Setup the full Lian Range inc accessories in 1 week - thats aprox 500 items. Then you can whine! ;)
Easy, descriptions are done for you, no options, no testing to be done, easy work that I did whilst you were still in dipers, sunbeam cough, sunbeam. ;)
BANTER! :D
These look excellent, i think if i saw a review then i might be tempted to start recommending these to people that ask.
HI there
Here is the 15.6" version with 1920x1080 IPS panel with numeric keypad:-
OcUK Professional W550 UltraNote Pro 15.6" LED True HD Intel Processor, DDR3, SSD / HDD, Intel HD 4000 Graphics - Windows @ £655.00 inc VAT
This Professional W550 UltraNote Pro is an user-customisable Laptop which means you spec it and we build it and can delivery as fast as next day when FAST TRACK service is selected. Built around an UltraNote Pro W550 chassis which is very similar in size dimensions to an Ultrabook though marginally larger as it also features an optical drive. Even more the marginal size increase means far superior performance from the Core i5and i7 processor options with dual/quad core plus hyperthreading. The biggest bonus is the inclusion of Intel HD 4000 graphics compared to an Ultrabooks HD 3000, this means 3D graphics performance is vastly superior.
So enjoy superb performance from this very small, compact and stylish OcUK Professional W550 UltraNote Pro. Ideal for any professional user who travels a lot and has to work on the move, but at the same time can take a break and play games as well. This Pro version also features a larger 15.6" True HD 1920x1080 resolution IPS panel making it perfect for photography/photoshop work with accurate colours. Also features a full size numeric keypad too!
You can now have us build you your ideal specification of UltraNote Pro and get it delivered in no time at all, what are you waiting for? Our UltraNotes also come with zero bloatware, so they perform at maximum performance ALWAYS.
Specification:-
- Operating System: Select from drop downs
- Display: 15.6" SuperBright LED True HD IPS Display (1920x1080 Resolution)
- HD Audio
- Physical Specification: 374mm x 252mm x 14mm ~ 25.4mm (2.20kg with battery)
- Bluetooth Support
- 1x HDMI Port
- 1x VGA Port
- 2x USB3.0 Ports
- 2x USB2.0 Port
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- 9in1 Card Reader
Service Package
From £655.00 inc VAT.
ORDER NOW
Are there any reviews about for this chassis? My dad is after an upgrade for his laptop and was looking Ultrabook, but his failing eyes might like 15.4" of screen.
How long is the TWO Deal on the Ultranote? I see it has only just gone on offer today?
Also, does the 15.6" screen have the decimal point on the numeric keyboard in a funny place? I cannot tell from the screenshot.
