OCUK V8 kit
16 May 2010
Hi all, I'm fancing a dabble with water cooling and this looks like the place to start but I've a couple of questions.
Will this fit into a Corsair 600t?
And say down the line I want to move into a CPU/GPU loop would I be able to just swap the radiator out or add another rad without replacing the pump/res?
And also I like the look of the compression fittings. Would these http://www.overclockers.co.uk/showproduct.php?prodid=WC-064-OE
go on as a straight swap for the supplied barbs?
Thanks in advance.
hi there, i would measure from the top of the case to the mother board as the 600t can only fit slim rads.......i couldnt fit a rad with anything with a depth over 30mm , but i think this is dependant on mother board in use.......
yes, but not with the fans i don't think
you can add another rad with modding
yes
Thanks in advance.
It should fit as that rad is the same one I have in my Fratal Design Arc Midi. I can't even see the rad xD. Measure from the grill to the highest point.
Thanks for the answers, however I'm away working at the moment so it'll be another couple of weeks before I can measure up and see what its looking like!
wouldnt say all rich.....dependant on motherboard......heres my 600t with a gigabyte z68-ud7b3 and a 30mm rad......no way i would squeeze a 35.5mm rad up there........
