OcUK Value 2GB Dual channel kit problem
28 Dec 2005
Manchester, UK
Recently got this: https://www.overclockers.co.uk/showproduct.php?prodid=MY-010-OK
Everythings fine except that its not running in dual channel, ive had a look in my BIOS but cant see if theres anything I should change. I always thought that if as long as you put them in the right slots it would work dual channel automaticly.
Ive checked that they are in the correct slots but no luck.
Any suggestions ?
The saaayyymmeee colour you say? I thought it was opposite colours :P
Example
Slot 1 - Blue----|Dual
Slot 2 - yellow--|Channel
Slot 3 - Blue----|Dual
Slot 4 - yellow--|Channel
But I will try putting one in slot 1 and one in slot 3, and then slot 3 and slot 4
Snapshot said:
1 & 3 or 2 & 4 is what you need.
^ that's what you need.
They used to have all DIMM slots the same colour, but they now colour code them so its easier for people to setup and use dual channel.
