690 SLI would be completely pointless!
I chose win 7 pro as it was the only one in stock
PSU - i'd still go for strider. Both PSUs are amazing, but the strider is £60 cheaper
RAM, 64GB is horribly overkill unless u need lots for a specialist application
Watercooling has virtually no impact on the performance of RAM, pure looks
That RAM you have linked to isn't watercoolable
Pump tops - minimal/no difference
IMO, the Aquaeros above the LT are a bit of a waste of money. All the screen is used for on my pro is to tell the time, so no, i don't think the XT is worth the extra
DVD drive - go for looks
EK blocks were chosen because they are, IMO the best looking. They are also amongst the best performers in terms of temps so for me, EK is currently the best watercooing brand overall
XSPC rad - slim and good quality
Masterkleer - very clear an tight
Mayhems - CS from mayhems is great and the fluid is very nice too.
Fans - They were, IMO, the best looking
To improve performance, there's not that much you can do because you already have plenty of rad space to components ratio. However, if you really wanted to, i'd change the rads to 480mm and 240 and use gentle typhoons and change the EX rad to another SR. This should give excellent silence and plenty of cooling, however, if it were me, i'd keep the 560 and 280 with LED fans as the performance differences will be minimal and in cases like this, i believe that you may aswell go for looks. When spending so much, you need to show it off
