OcUK Website Certificate Problems
Caporegime
25 Jul 2003
FR+UK
Just wondering if anyone else can verify this..
The OcUK shop (basket, https://) security certificate authenticates fine in Firefox:
But doesn't authenticate in IE7.
My browser/network settings? Or a security risk with using IE.
hmmmm make sure the correct ssl is enabled.
Tools -> Advanced -> and scroll to the bottem where you should see
Use SSL 2.0
Use SSL 3.0
try changing them around a bit and see if that does anything.
i know i shouldnt say but in all honesty just stick with firefox / opera.
Tried both SSL2 and SSL3 and check-box combinations thereof, still no luck in IE.
I use Firefox myself, but someone in the office was buying something and using IE, which is why I noticed it. And I'm sure a fair few people buying stuff off OcUK use IE, so if it is a problem and not just his PC/my network it'd be good to let them know.
flump said:
Have you got the lastest root certs update from windows update?
Yup.
Telescopi said:
I have IE7, it's fine.
Something on this end then, thanks Tel.
