Oculus link cable
17 May 2013
West Sussex, UK
I did have a quick browse and surprisingly OCUK are the cheapest at the moment.
I've gone for the Anker which should be good enough to get me going over xmas.
virtual desktop all the way, i haven't used the long cable since i bought the app.
I've seen this mentioned a few times. It allows the Quest to connect to the PC via WiFi?
I assumed it's not as good as USB or otherwise no one would buy the cable?
I'll certainly have a look at it though
Its dependant on your router and signal how well it works.
Apparently, hinting but not mentioning competitors is verboten, so you may want to google for link cables, and there may be other sites that come up with the cable at half price.
think thats the cable i use to
(i got mine with the Quest 2 though as i got 2nd hand)
mines a C to C, so had to buy a USBC-USBA 3 dongle
