There is not such thing as a "gaming pc"... that term gets trown around way too much, but it essentially means a high end machine (expensive CPU/GPU), not anything special.
The Oculus has minimum system requirements that need to be met in order for you to be able to run games on it - thats it.
https://support.oculus.com/248749509016567/
The above page will tell you everything you need to know.
If your computer can cover at least the minimum, you should be able to run it. Obviously that also depends on the different games you want to run, because some require more powerful components.
