OCZ 2000MHz Memory Deals
17 Oct 2002
Stoke
OCZ Gold 6GB (3x2GB) DDR3 2000MHz PC3-16000C10 Low-Voltage Triple Channel (OCZ3G2000LV6GK)
The OCZ PC3-10666 triple-channel memory kit is designed specifically for the Intel Core i7 processor / Intel X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency. Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 2000MHz DDR3
- CL 10-10-10-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Just £97.99 Inc. VAT
BUY NOW
OCZ Blade Series 6GB (3x2GB) DDR3 PC3-16000 Triple Channel (OCZ3B2000C9LV6GK)
The Blade Series Triple Channel Memory kit is the latest maximum-performance RAM designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. At DDR3-2000 CAS 9, the Blade Series harnesses industry-leading speeds at the low voltage required to safely run Core i7’s triple channel mode. With the ideal combination of all the factors that formulate the ultimate memory solution— density, speed, and an effective new cooling design—the Blade Series is guaranteed to please enthusiasts looking to take the hottest Intel platform to new heights. The Blade heatspreader aims to enhance heat dissipation to improve the longevity and stability of the modules while keeping a sleek, low profile. The new propriety design has numerous channels that increase the surface area to more efficiently offload heat away from the memory chips and PCB. Push your gaming or overclocking rig to the extreme with the superior thermal solution and unmatched speeds of the high-end Blade Series memory modules. Whether seeking maximum frame rates in the latest PC titles or yearning for the highest benchmark record, the Blade Series was developed for gamers and overclockers looking to make the most of their high-performance systems.
- 2000MHz DDR3
- CL 9-9-9-30
- Triple Channel Optimized Kits
- Unbuffered
- 1.65 Volts
- 240 Pin DIMM
- Pure Aluminum Heatsink
- OCZ Lifetime Warranty
Just £103.99 Inc. VAT
BUY NOW
Hey Adam, forget to do anything yesterday? ;)
Just kidding of course, I know how busy you must get. Just give me a shout when you get the time. :)
would this ram be any good in your overclocked 4ghz bundles on the gigabyte ud5 board ? would it make any difference ?
cheers
karl
