OCZ 2GB (2 x 1GB) PC2-8500 1066MHz SLI-Ready Edition Dual Channel DDR2
16 Feb 2007
Is this the best memory to get - end of? I mean this is gonna go into an Asus Striker Extreme mobo most probably - running with a QX6700 cpu. The price is great and the speed looks good. What u fellas think? Get this one... or is it not such a great oc'er?
I cannot use dominator with my Amanda Tec cooler from what I'm told since they are large ram sticks that will get in the way.
Thanks for your reply :D
So it might be that I have to give OCZ a miss then (shame, was nice n cheap) was wondering why...
what about this... would I be better off with
CellShock 2GB (2 x 1GB) DDR2 PC2-8000C4 1000MHz Dual Channel Kit
(reason being that it might have more OC headroom i dunno??) Heard that timings are not as important on Intel cpu systems.
or the one you suggested ?
Team Xtreem 2GB (2 x 1GB) DDR2 PC2-6400C3 800MHz Dual Channel Kit
I have been looking into faster memory and Cellshock is certainly worth getting but,look into what Asus recommend for the board, I think this board may have issues with some vendors.
OCZ has always worked fine in all Asus boards that I've owned
Crucial Ballistix is a pretty safe bet as well
Problem is that those lists are never complete :(
Another thing is that I'm thinking of getting 4GB instead of 2GB... not sure how that would fare, but then again, need advice on it all (tho i find that its a question that is repeated often - no clear answer yet)
So has anyone used Cellshock with an Asus Striker Extreme?
