OCZ 2GB DDR2 800MHz PLATINUM XTC
6 Apr 2007
Portsmouth
How is this RAM? It seems to be at the cheaper end of the line so I was just wondering if there was any reason for this. I'm aiming to get my CPU at around 3.6Ghz, my current memory (Corsair XMS 667Mhz) can't keep up.
Just wondering it matches up and if there is anything I'd be better off getting?
Thanks
It's very solid memory. It's 'cheapness' has nothing to do with the product, and everything to do with the current state of memory prices.
And it will easily keep up with an E6600 @ 3.6ghz.
I'm using the Platinum Rev 2, and it's great memory. The only issue I noticed is that the heatspreaders don't seem to stick well in the middle. Not much of a problem though, as I slapped an OCZ XTC memory cooler over the top! :D
How flexible is this memory and what max MHz speeds have people been getting on average?
Also do you still have to send OCZ sticks back to the USA for RMA's?
