28 Jun 2007 at 16:53 #1 kkthxbye kkthxbye Associate Joined 29 Apr 2007 Posts 483 Location Teesside Uni As title really, what command rate does this ram run at? Cheers
28 Jun 2007 at 17:01 #2 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,431 Location Antrim town Whatever your motherboard allows you to set it at. Tho I'm not sure if any boards will allow 1T at 1066mhz.
28 Jun 2007 at 17:32 #3 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Its not the mobos its the ram, and ddr2 is offically 2T, think its OCZ are due to release 1T, if you can run 1T cool. Last edited: 28 Jun 2007
28 Jun 2007 at 17:39 #4 kkthxbye kkthxbye Associate OP Joined 29 Apr 2007 Posts 483 Location Teesside Uni cheers guys
28 Jun 2007 at 19:15 #5 Type_R Type_R Soldato Joined 18 Oct 2002 Posts 6,222 Location EGBB Good luck with running it at 1T, mine really doesnt like it
28 Jun 2007 at 22:19 #6 kkthxbye kkthxbye Associate OP Joined 29 Apr 2007 Posts 483 Location Teesside Uni yea same here, just locks up
1 Jul 2007 at 19:07 #7 Barf01 Barf01 Associate Joined 25 Jun 2007 Posts 6 Should not be a problem I am currently running 4 gig of these on my BFG 680i Vista 64 @ 4-4-4-12 T1 940mhz with no probs whatsoever. I cant get them above this @ these timings but at this speed the are running faster than my FSB anyway. So yes if you drop the speed a little you can tighten up your timings and run these in T1. Good luck
