- 25 Sep 2003
- Manchester
I have two sets of OCZ 4GB (2 x 2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) and am overclocking my pc at the moment.
I have a few questions as i'm a bit confused
1) Should this RAM stay running at 800Mhz or below or is going higher going to give me benefits?
2) If I do go above 800Mhz will I need to increase the RAM volts to keep stability?
3) Is it better to have tighter timings or higher Mhz?
4) My CPU is running at 3240 (380x9) which means my Rated FSB is at 1520, is that ok or should I try and get it higher, will this make the system faster overall or just CPU Mhz?
I tried setting my divider to give me a good match with my CPU but the closest was around ~916mhz so over the rated 800mhz, my machine needed a BIOS reset after that heh. Wasn't sure if I should start increasing the juice or if this was a bad thing to do? If I want my ram anywhere near the rated 800Mhz then I have to drop my CPU down or put it up to ~3.4 so that's why I'm wondering.
