Hi Guys,
I'm trying to upgrade my old gaming PC (which I now use as a server) from 4GB to 8GB of RAM. With DDR2 RAM costing an arm and a leg now i've resorted to looking at used stuff on fleabay.
At the moment I have 4 x 1GB sticks of OCZ SLI Ready RAM (http://www.ocztechnology.com/ocz-ddr2-pc2-6400-sli-ready-edition-dual-channel-eol.html).
I found on eBay 2 x 2GB of this OCZ Platinum RAM (http://www.ocztechnology.com/ocz-ddr2-pc2-6400-vista-performance-platinum-4gb-dual-channel.html).
So I purchased them and figured an upgrade to 6GB would do for now, but am gutted to find that they don't work with my current RAM. Any ideas why?
The motherboard posts fine with just the platinum RAM in but when I add 2 x 1GB of the SLI ram too it won't post, I've tried clearing the CMOS and no luck. I'm guessing the timings just don't match up, if this is the case I guess my option is to try and find another 2gb sticks of the platinum RAM, I have found this ebay auction - http://www.ebay.co.uk/itm/4gb-2-x-2...-5-4-4-1-4-gb-kit-/261076538080#ht_581wt_1163, will these work with the other platinum stuff I got?
By the way my motherboard is an Abit IP35 Pro.
Thanks!
Alex
Thanks!
Alex
