Its been a while since last post on here but incase anyone does read it, i just put my core i7 setup together.. and Im totally lost when it comes to overclocking on the i7 platform.. well about the reapers, after about 30min of messing about with various settings (which I didnt understand) my sticks are running at 7-7-7-18 1T (665Mhz) 1.65v.. thats with timings set to auto. Havent tried to get the highest speed possible just yet. I will experiment somemore and try getting the rated 1866 speed.
Im quite happy so far as I was after ram which could run higher speeds but also run lower speeds with tight timings and so far I can say thumbs up for the tight timings category. Will run like this for a while to test stability over time. (SuperPI 16m stable)
will post more updates once I get time from work to mess around some more.
Hope this is helpful for anyone looking to buy this stuff.
setup
Core i7 965 (3.7GHz stock voltage)
Foxconn Bloodrage lga 1366 mobo
6gb OCZ reapers
