ocz ddr3
26 Apr 2008
York
hi there, when i run the memory in my sig at 333 (default) i get no errors in memtest, however when i up the fsb to 400 i get a continious stream of errors being reported, any suggestions?
Thanks
as far as i knew yes, i set the voltage at the max recommended 1.9v will try loosening timings and see if that helps
If the memory is 1600mhz stock volts and timings should return no errors in memtest. If it does the sticks are duff and need RMA'ing. Try testing seperate sticks first to see if it's just one.
