Ok, I read on the ocz site that the settings were cas 2, trcd 3, trp 3, tras 8. I looked around in the bios and made the changes so I think these are correct.
It also says voltage 2.8v but in my bios it says dram voltage is 2.6v, will that be ok or should I up it ?
Thanks.
yeah up the volts to 2.8v as long as you have decent airflow through your case should be fine, thats what they are rated at so no probs, ram setings look fine.
