I bought a Corsair 620w to replace an OCZ GameXtream 700w and thank god I did... cable management is about 10x easier, it's quieter, and the 12v rail is also steadier.
I've got:
E6600
Asus P5B Motherboard
4GB of Geil Ultra Low latency
X-Fi SC
WD 250GB SATA Drive
and a Few 120MM fans
Will be getting an 8800GTS at the same time. I would've bought an Corsair 620W, but the OCZ one was cheaper. I'd like to have the modular stuff, but i can live without if i save money Bit overkill for my system, but its so i don't have to upgrade my PSU again should i decide to upgrade my gfx or CPU in the future
I've used a 600w GameXStream for 6 months, has performed faultlessly, on the point about the cable management, it could be done better on the GameXStream, but apart from that a very good PSU.
I have the 600W version - got it from the OcUK clearance section for £50. It's quiet enough and has been reliable so far - not great if you want to post on a 'rate my cabling' thread though
