OCZ ModStream 520W
  • Thread starter Thread starter Neb
  • Start date Start date
Neb
Neb
5 Dec 2004
Is this PSU any good? I saw that it only had 26 amps on a single rail, will the be fine and future proof? It's also going in a qpack, so if anyone has any comments about how well it would fit that would be good too.
Thank You.
It's a pretty decent PSU. Check your components to be sure you won't exceed the 12V rail's current allotment. OCZs are essentially gussied-up FSP power supplies so you might save some money and go with an FSP instead.
Good PSU, just make sure you haven't got a case with a fan on the top of chassis, in front of PSU. Gets in the way of the mod connectors.
Also, the cables are a bit stiff, other than that they are a good PSU, and quite pretty as well :)
