OCZ -=OR=- CORSAIR
yeh i got ocz sli memory and i havnt looked back... did have corsair but my motherboard did not like it one bit
Neither. Just get some Ballistix PC5300 and experience practically identical performance for a lot less money. :)
Holy mother of god your sig's huge!!! :eek:
Might wanna resize that badboy. Needs to be 400x75 and no larger than 20k.
gt
Right installed the OCZ, but in the bios its coming up as the same timings and latencys as my previous ram. do i need to manually adjust them? I thought it would auto do it?
If you set the timings to "Auto" then it should automatically configure them to whatever the SPD data tells it.
To be honest I'd just set them to what they should be anyway. :)
Ah! didnt think of that! Havent altered any voltage, what would you think it should be set to? Its actually been running 1066 for a few mins ok now.....
