Hi,
This is probably an easy question: I bought the Overclocker's ultima system back in March, and it comes with 2 x 1Gb of OCZ PC2 9200 with what I think is 5-5-5 timings (yes, I did open the case to have a look). I can't find the original webpage cached up on google to check against.
Is this the same as:
http://www.overclockers.co.uk/showp...HPC Edition Dual Channel DDR2 (OCZ2RPR11502GK)
- I want to fill the final two sockets. If it isn't the same do I have anything to worry about?
Thanks all,
B.
Thanks all,
B.
