OCZ Platinum - Better if your not upgrading?
17 Feb 2006
OCZ Platinum - Better if your not Overclocking?
Will it make a lot of difference if I go for some OCZ other than the platinum if I dont overclock?
You can't delete. One thing though, you don't state which memory you are looking at or 2GB or 1Gb kits. If you give me that info, I can sort you out with an answer.
The rest of your system specs might also help.
