After crying about the rev.2 being cheaper than the rev 1 i bought around 1 month ago, I'm over it, but I'm still trying to make the most out of my RAM.
At the moment I'm running at 430MHZ FSB so 860MHZ with the RAM. I have a DS3 and am running the RAM on auto, but I want to tighten the timings if possible.
Currently i have timings of 5,6,6,17 but I'm sure it's possible to decrease this, I was just wondering what kind of timings I should be looking at. (It says 5,5,5,15 at 800MHZ - so I'm sure I should be able to get near / past that)
So basically, what kind of timings would you tighten them to, and what overvoltage should I use (it's at +0.3 atm, but that was following the advice on the CPU clocking, maybe i put it too high [i read that performance RAM should have an extra 0.2-0.3 volts to run properly])
(anyone with this memory would be very helpful if you posted what you managed)
Cheers.
Cheers.
