OCZ Power Supplies?
thats still the same price as when it was on special offer. and I am 99.9% sure of this.
OCZ PSUs have proven reliable and quiet to match. Just make sure you check how many connecters (PCI mainly) you need, as Corsair PSUs tend to come with more than OCZ PSUs.
Yes, it does say 10 in stock I checked that before I drove down there but they said they had none in stock - sold out yesterday:confused:...perhaps have some more in later! I rang them again at about 4pm but they still don't have any, maybe tomorrow:(. So I just wondered about the alternative they offered in case the Corsair is still not in stock tomorrow.
Thanks
Vikki:)
It near as damn it makes no odds vikki. The OCZ is geared towards keeping sound to a minimum, I seem to recall you wanting to use the rig for recording so that may appeal to you on the audio aspect.
These PSUs aren't modular so things could get a lil untidy in the case. Maybe you could ask for a modular version of the PSUs to help airflow.
Look forward to seeing how well the build goes
I got a 600w ocz psu and wouldn't recommend it. Not becuase its bad but due to the fact that it has only 2 pci leads, if you want sli/xfire you need adapters which sucks imo.
im using the ocz 600 watt one in my rig and its performing pretty well plus its quiet :)
edit : had to recently buy a molex to sata adapter though as it only has 3 sata power leads on it, but my dads one is the 700 watt version and has 6 sata leads on it :)
I got an OCZ StealthXStream 2 400W Power Supply for my home server, and it's excellent. The 120 mm fan is thermostat-controlled so the fan doesn't even turn. Just check it has enough connectors for your needs and you should be good to go.
The tension mounts.........
You're so right:eek:
I have a pile of parts here and just wonder if I can get it all together.....:(
I think I'll open a new thread called 'Vikki's computer Daw build' where I can ask some questions and perhaps some of you guys could help me out. My brother said he'd help me but I think seeing all the parts as we collected them together has frightened him away:mad:
Here goes...................
Vikki:D
