OCZ PSU Cable Mod Help please
24 May 2011
West Sussex
Hi, i have an OCZ 850W z Series PSU in my white 600T case and the yellow PCI cables and connectors look foul.
I am going to be the white bitfenix alchemy cables from OCuk for the most visible parts that attatch to the MOBO and GPU but what can i do about the psu end of the cable because the plug is yellow and the cables are visible and i want my case all pretty and nice :)
Here is a picture to help explain my situation as i don't think i have done a very good job.
Red Arrows are the bit i need help with.
Green arrows are where i will buy alchemy white cables.
(Plus alchemy's for the front I/O cables)
Uploaded with ImageShack.us
could you make some sort of cover that goes between the PSU and HDD cage?
as someone with no modding experience it seems like the easiest solution, but im happy to be proved wrong there
It would be possible, but would be a lot of work i think. An easy solution would be preferred, but thanks for your idea.
You can buy several different colour connectors on a certain online retailer. A straight paperclip will allow extraction of the terminals. Simply grab some black connectors and swap them over.
As for the yellow cables maybe a little bit of braid or heatshrink over the yellow visible ends.
Obviously you cannot name the seller. But can you give me the exact name of the product for me to search?
