ocz ram and ds4 bios help?
18 Feb 2007
London
hi
i need some help on where i enter the ram timeings for my ocz 6400 platinum revision ddr2 2 gig ram (the offer one on oc)
should i enter 4-4-4-12 or 4-4-4-15 ?
also do i enter it under the following in my bios (ds4)
CAS lattency time- 4
dram ras to cas delay-4
dram ras precharge - 4
precharge delay (tras) -15/12
What's written on the sticks? It usually says either on the sticks themselves or the packaging. Try low numbers and if it passes memtest, keep them. It's not uncommon for 4-4-4-15 PC6400 to run 4-3-3-8 as usually it fails the CAS test first. Your RAM is only as fast as the highest number quoted.
