OCZ RAM SETTINGS?
25 Feb 2008
Hey guys just built my pc recently my ram settings on the bios arnt all correct. Not sure what settings their should be?:(:confused:
I have OCZ 4GB (4x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC
and the ASUS P5E X38 MOBO and E8400..
Please give me exact settings please??
Screenshots if possible..
Thanks..:)
Yip 'DRAM Voltage' is the memory voltage setting on that board.
Also raise the Northbridge Voltage by 0.1v above the lowest setting to boost the board for running four sticks.
i have 4x1GB OCZ Platinum v2.
i have found, running it at 4-4-4-12, 800Mhz 2.0v is perfectly stable.
but anything above 840Mhz will fail completely, no matter how loose the time is, and now much voltage i put through it.
btw, you guys splashed out on CPU, but bought some cheap RAM?? im thinking you guys will not get to 4Ghz with those RAM, i cannot get to 4Ghz with my quad core just because of my RAM is very unstable at anything higher than 840Mhz.
