ocz reaper help needed pls
10 Sep 2008
Hi,
My setup is an m3a79-t mb with a phenom 2 940 @3.ghz. So no overclock.
but i just cant seem to get my ocz 1066 ram to work.
I have set manually
- voltage 2.1v
-timings 5,5,5,18
-freq 1067
-in dual channel i either dont post or if i do i eventually get bsod.
-in single channel i get up and running but start having problems like programs crashing/freezing etc. and possibly bsod.
tested them with wmd and when it bsod in dual channel wmd was failing on everything but then tried each stick individually and they passed. Put back in the two sticks and then they both passed.
tested with memtest86 over a 2 hour period-pass
if anyone has had similar problems with this mb/cpu and ocz ram can you please tell me how you fixed it. or if anyone can throw in any suggestions to get it working i would be greatful.
Driving me Nuts, if you can sort this then you are just a complete legend.
oh and they are the 2*2gb sticks.
part no- oczrpr10664gk
ok everyone.
My timimngs etc i have all set manually but maybe i have set them wrong i have this information which im not too sure on.
DCT0 1st information 5-5-5-5-18-8-75-127.5-75
DCT0 2nd information 75-32-4-4-3 (5)
DCT1 1st information 5-5-5-5-3(5)-18-32-8
DCT1 2nd information 4-4-75-127.5-75-75
im running them unganged as tgis seems to be better stability but with them like this i get a lot of crashes and bsod due to memory management.
pls help.
Hi,
I have set manually
- voltage 1.2v
-timings 5,5,5,18
-freq 1067
Voltage needs to be 2.1v ( 1.8v at a minimum ).
not really but when i memtest them single they pass ok, right now i have been running for about 2 hours with no bsod with 2 sticks but it will come.
