8 May 2009 at 14:07 #1 Ronaldo Ronaldo Associate Joined 18 Nov 2003 Posts 1,803 Hi guys i have this septup here, minus that watercooling kit (i have a tigar instead) Which cooler are you using with your reaper? i want one that will use 12cm fan for best cooling. cheers
8 May 2009 at 21:25 #2 Ronaldo Ronaldo Associate OP Joined 18 Nov 2003 Posts 1,803 some must have the reaper lol
9 May 2009 at 01:57 #3 setter setter Caporegime Joined 14 Dec 2005 Posts 28,067 Location armoy, n. ireland The reaper ram doesnt need extra cooling, ive used both the pc6400 and 8500 kits and heat has never been an issue.
9 May 2009 at 14:15 #4 Ronaldo Ronaldo Associate OP Joined 18 Nov 2003 Posts 1,803 i mean for my cpu but reaper stick out so much need a cpu cooler that will fit the setup
9 May 2009 at 14:16 #5 reflux reflux Soldato Joined 15 Nov 2007 Posts 13,177 Location Hertfordshire EDIT: Post comprehension fail. Sorry. Last edited: 9 May 2009
9 May 2009 at 14:17 #6 CliffyBiro CliffyBiro Caporegime Joined 1 Mar 2008 Posts 26,303 I use an Akasa Evo. All depends on the layout of your mobo though.
9 May 2009 at 14:24 #7 Ronaldo Ronaldo Associate OP Joined 18 Nov 2003 Posts 1,803 how good is that cooler? i have q9550 and i would like to hit 3.5ghz if i can
