- 26 Jan 2005
- Newcastle, UK
Hey all,
I've just got my new system up and running:
- Q6600
- 2x2GB OCZ 1000MHZ Reaper X DDR2
- ASUS P5KC
- 1x 8800GTX
When I set up the system, at default the memory is clocked at 2x400(800mhz), which obviously works fine, but because the memory is advertised at 1000mhz, I'd be happier to run it at that speed. I don't know an awful lot about overclocking, but I understand the basics.
I can't for the life of me get it to run at 2x500(1000mhz), I'm not sure what I'm doing wrong. I've disabled C1E and increased DRAM voltage to 2.1v as recommended by OCZ.
At the moment, I've got the system running at 2x400(800mhz) at 2.8GHZ with a 4:5 cpu:ram ratio, whenever I try to get the memory close to 1000mhz, it just doesn't like it, whether the cpu is running at stock, underclocked or overclocked.
Any ideas?
Thanks in advance.
- Q6600
- ASUS P5KC
- 1x 8800GTX
Any ideas?
Thanks in advance.
