OCZ STEALTH-X-STREAM II POWER SUPPLIES - ARRIVING TOMORROW
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
OCZ's latest StealthXStream 2 PSU's are 80 Plus Certified to ensure great efficiency.
OCZ StealthXStream II 500W Power Supply @ £57.99 inc VAT
The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value. Designed for both gamers and mainstream power users in mind, key features of the sleek StealthXstream II include a thermally controlled 120mm double-ball bearing fan maximum airflow at near-silent audible noise levels, exceptionally well regulated electrical noise and ripple for stable operation, an ideal array of connector types for each wattage, and excellent efficiency, converting up to a full 82% of AC to DC power at typical loads. The StealthXstream II Series from OCZ is fully compliant with the latest ATX12V and EPS12V specifications.
- Series: StealthXstream II
- Type: ATX12V V2.2 / EPS12V
- Wattage: 500W
- Fan Size: 120mm double ball-bearing
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 2, PCI-E Connector: 1 x 6-Pin, SATA Power 4
- Efficiency: Typical load 82% Efficiency
- Energy Certifications: 80 PLUS Certified
- Input Voltage: 100 – 240V
- Input Frequency Range: 50/60 Hz
- Output: +3.3V@24A,+5V@24A,+12V1@18A, +12V2@18A, [email protected],+5VSB @ 2.5A
- MTBF: >100,000 Hours
- Dimensions: 15cm x 8.5cm x 14cm (W x H x L)
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 6 x Peripheral, 4 x SATA, 1 x Floppy,
Only £57.99 inc VAT.
ORDER NOW
OCZ StealthXStream II 600W Power Supply @ £66.99 inc VAT
- Wattage: 600W
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 4, PCI-E Connector: 1 x 6-Pin +, 1 x (6+2-Pin) PCI-E, SATA Power 4
- Output: +3.3V@25A,+5V@25A,+12V1@18A, +12V2@18A, ,+12V3@18A, +12V4@18A
[email protected],+5VSB @ 3.0A
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 1 x 6+2-Pin PCI-E, 6 x Peripheral, 4 x SATA, 1 x Floppy
Only £66.99 inc VAT.
ORDER NOW
OCZ StealthXStream II 700W Power Supply @ £79.99 inc VAT
- Wattage: 700W
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 4, PCI-E Connector: 1 x 6-Pin +, 1 x (6+2-Pin) PCI-E, SATA Power 8
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 1 x 6+2-Pin PCI-E, 6 x Peripheral, 8 x SATA, 1 x Floppy
Only £79.99 inc VAT.
ORDER NOW
The differences are as follows:-
80 Plus certified
2 extra molex connectors
2 extra SATA connectors
Better, quieter, higher airflow fan.
The original Stealths are end of life, so they won't be available much longer.
ok, I ordered a Titan Exodus at the start of the week when it said it had the TX650 in it. Would you mention something if it turns out to have a OCZ PSU instead?
