- 4 Oct 2007
- Belfast
Right, I've just spent ages fitting this flipping thing (and doing some minor case mods too), and now the PC is back online! Ill edit more details (and a few crappy pics too) after I've had some sleep and a hearty breakfast, but to cut a long story short:
CPU: E8400 @3600 MHz (400x9)
Old temps under Prime 95: 75/82 C
NEW temps under Prime: 45/55 C
It's also a heck of a lot quieter than the stock fan, didn't realise just how noisy it was!
And I'm NEVER using high tension push pins EVER again!
UPDATE!>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
I should be in bed now, but I'm running orthos for a 3.8 GHz o/c on the e8400
When I went to install the cooler, I decided it would be a great time to dremel a few holes in the case (Thermaltake Armor Jr.... yeah, I know, got it 3 yrs ago when I diddnt know better!) at the same time to aid the lack of cable management in the case.
First, the old setup: (btw crap phone camera!)
And the holes drilled:
This took most of the day to do, as I had to go and play a gig half way through! By the time it was done, it was well and truly dark outside.
Rather than leave the putting together till the morning, I started right away, hoping to at least get windows booted before I went to bed.
The cooler:
As I said above, the high tension pushpins are a NIGHTMARE. I honestly thought I'd cracked the board. Indeed, on inspection I find the board has been bent by the amount of force required to install it
It's a bit hard to see with the crapy photo, but there definitely bending going on there! The pic is taking looking at the top of the board:
I do have a mounting kit on order, but it's out of stock (only the i7 kits seem to be in atm, if OCUK had the 775's, id order them like, right now!), I was just doing this because I felt my life could no longer go on without this cooler in my system NOW!
Anyway, after putting the board and PSU back into the thermalcrap case, I encountered a problem. How in the sam hill to get the 8-pin CPU connector into the top left corner of the board?!?! It was a pretty tight squeeze that required the help of a trusty pair of needlenose pliars! For reference in the pic below, there's just under an inch clearance between the top of the cooler and the PSU rail.
After that it was all plain sailing to get the hdd's etc. all plugged in. Cable management's still crap as theres so little room to the side of the mobo, but I got it mostly sussed
With the black SATA cable running on top of the other cables, it hides them all nicely, looks much better in real life!!!
Oh, a funny story:
I built this system nearly a year ago, haddn't taken the CPU out since. I'm an AMD man really, this was my first intel build (have done several AMD for friends and family since). Now, being an AMD man, the CPU pins are ON the CPU. So I'm sure you can imagine my absolute HORROR when I took the CPU out of the socket to clean and had a look underneath, only to find THERE WERE NO PINS!!! Im my blind panic I looked at the mobo and thought "How did I manage to break them off so cleanly in their sockets and not bend them?!"
After 5 minutes and a beer I had recovered enough to continue!
The cooler:
Oh, a funny story:
