Hi all,
got this cooler recently to hopefully lower my Temps and up my clock.
I originally went to my PC shop looking for a Tuniq but he couldn't supply it and offered the OCZ as an alternative.
Lookes just like a Scyth?
Anyways, I'm currently using the Freezer 7 Pro keeping my overclcoked to 3.4Ghz Q6600 at 39 degrees idle and 80 degrees load.
I'm using Artic Silver 5.
I know I've a good O/C and 3.4Ghz but I feel I could do better.
BUT...
Temp at load is too high for my liking hence getting new cooler.
(I had a credit note from the shop and wanted to use it).
Whats the crack with the OCZ Vindicator guys?
Reviews seem to suggest its an "ok" cooler with the stock fan, but up there with the Top 3 when a better fan (SilenX IXTREMA 120) is used on it.
Will this combo (OCZ/SilenX) out-do the Freezer 7 you think?
Suppose getting to 3.6Ghz would be good - but it has to be STABLE!
Asking here to check if any of you guys have hands on experience with this thing.
Thanks!
BUT...
Thanks!
