- 30 Dec 2003
Hey,
A little problem I hope you might be able to help with! This has been happening for several months now but only now has it bothered me enough to want to rectify it!
If my PC is off for a substantial amount of time (Overnight, for example) then it turns on fine. If however the computer has been shut down and I immediately try to turn it on I do not get the POST "beep" and the computer never comes on. This same problem happens even if the computer has been off for a short amount of time (For example if the computer is turned off at 9.30pm and I try it again at 10.30pm it never boots).
The only temporary fix I've found (And what I've been using so far) is that when it exhibits this behaviour actually removing the computer plug out of the wall socket (I usually turn the power off at the wall but do not remove the plug). Leaving the computer physically disconnected from the wall socket for some amount of time (Appears to vary!) it will then boot fine.
Does anybody have any ideas why this may be?
Cheers!
Cheers!
but current spec is:
