Ok, hardware:
BFG 680i
e6600
2x512 corsair xms2 pc6400
Basically, clocked or not clocked, cpuz detects the multi as being 6, but windows/orthos/bios detects it as being 9 (it is set at 9)
cpuz also states that the ram devider is 7/8 @ 350mhz fsb (ram is set to 400mhz) so this is correct, just the multi issue...
Whats up with cpu-z do you reckon?
EDIT: PCwizard also detects it as 6 (not got round to actually installing any decent monitoring software yet..)
Alos, never use orthos before, just prime95, whats the best way of stressing the system for stability? when i use default settings, some part of my computer makes an odd noise, pretty sure its not a fan.. but its almost like the noise of a cable 'just' being caught by a fan, not completely hit, but just touching like.. cant seem to locate where the sound is coming from..
BFG 680i
e6600
nothing to worry about.
