Odd case needed.
Permabanned
22 Jan 2010
Hi i have an idiotic mate how needs a specific case, is there one around?
it has to be a full tower, has 2 rear 120mm fans, and have a non screwless HDD soloution?
The PC-X1000 technically has two 120mm exhaust fans, just not next to each other - they are in different 'heat zones'. The HDD mounting also uses rubber-grometed screws, I don't know whether these would be ok.
Anyway, here's the link: Clicky
None of the other full towers from Lian Li have two exhaust fans...
How important is it that the fans are 120mm? Is it for a radiator in a watercooling setup?
If it's not too critical, Silverstone's TJ07 has two 92mm exhaust fans, and as far as I can tell, the HDDs are screw in. Clicky
