Hi all!
Hope this finds you well.
I've got a headscratcher on my work laptop.. it goes like this..
We have a vpn to an external service provider - this uses Cisco Anyconnect. It's always worked, but before Xmas it stopped working, saying it failed to connect. Looking into the Anyconnect logs I've found this error: 'no valid certificates available for authentication'. Went though troubleshooting with the external provider - all is fine their end. I have discovered the following..
I feel there is something hanging over it that I just can't find it.
Before I resign to a reinstall, I don't suppose anyone has any leads!?
Cheers.
- It won't work if I use my main wifi (192.168.1.x) or hardwire to my switch (with wifi off)
- It will work if I use my wifi guest network, same router (192.168.3.x)
- It will work if I tether to my mobile
- It will work on a totally different wifi network at a friends
- It will work on wifi/hardwire on my personal laptop
Still a big no.At the command prompt (decline restarting your machine until you have entered the final command):
- Type ipconfig /release and press Enter.
- Type ipconfig /flushdns and press Enter.
- Type ipconfig /renew and press Enter. (This will stall for a moment.)
- Type netsh int ip reset and press Enter. (Don’t restart yet.)
- Type netsh winsock reset and press Enter. (then restart)
Cheers.
