- 1 May 2007
hi there
I have just set up sky broad band for a friend
it is working fine using the netgear router it comes with if it is wired,
I have tried to setup a laptop which works fine when wired
when it works wireless it wont work as in sends more than it receives,
I thought fine disable that and try an external wirelss card, to work out if it was the cheap internal one.
However this is having problems as well, detects the wireless network connects fine the drops the connection the connects fine and drops again.
any ideas must be the router
cheers
nigel
cheers
nigel
