Odd Directory in XP
16 Oct 2003
C:\Documents and Settings\All Users\Application Data\{209C5FA4-5595-421C-846D-FD4A36F8AC22}
contains loads of sub-directories most containing dll files
Anyone know what this is?
Definitely Windows update temp files. Safe to delete.
Another quick tip while I'm at it:
Look in the C:Windows folder and open a folder called "Prefetch".
This is where files you have used build up in a sort of library of shortcuts to allegedly speed things up. It works for a while but soon gets cluttered.
Delete everything in it, run a disk clean up then a defrag and finally restart your machine. Your boot up times will improve no end.
Trust me....I'm a doctor! :cool:
Regards
AndyOcUK
OcUK Tech :)
