Odd error box-Steam.exe
2 Aug 2012
Just (Last few minutes) had a strange error box come up.
Cant remember the exact text but the Gist of it was that "Steam.exe cannot access drive E:, please insert disk"
I do not have a "drive E:" on the system
I do however have a card reader/USB slot designated as a removable drive in computer management/storage, The slot is not currently in use though it might have been about an hour ago (I say "Might" because I cannot remember exactly which slot is designated to which drive letter) but only to check some WP documents. I removed the USB stick correctly by using the "remove hardware" function some time before this happened.
After clicking cancel many times it went away. I then opened steam and loaded a game without problems.
What has happened here??
Should I worry about it??
