Odd GC temps when stress testing
23 Nov 2010
Been faffing with this most of the day as i've nothing better to do while im ill.
Been trying to get some max temps of the graphics and CPU. CPU is fine but the GC is very odd. My heating is useless so air temps are very low.
Card - Zotac GTX460 768Mb model standard clock speeds
Cooler Gelid Icey Vision Rev 2 using the paste included
for this the side panel was left on and a single 12cm intake fan. All Rheostated as low as they go.
Air temp - 13c
GPU temp idle 20-21c
GPU temp under load for two hours on 3D mark 06 loop - 23c
GPU temp after rolling demo of X3 reunion - 23c
Now, is the thermal probe fubar giving me the readings considering the CPU reached 26.5c under load from 20c in idle. I've been using speedfan for the graphs and Coretemp for spot temp checks.
Are the a bit idealistic or would you say they are roughly correct?
