Odd graw2 problem
1 Jun 2004
In nvidia control settings, if i put the slider on performance graw2 runs fine.
But if i put it on balanced of quality, the graphics go completely messed up. hollow textures, everything is grey.
Every other game i have is fine on all 3 settings (performance - balanced - quality)
odd :(
8800 GTX, with 163.11 beta drivers, vista 64bit.
Gerard said:
I get the same grey problem with the demo, for me though its if i set FSAA to override app setting in the control panel.
So if you set nvidia to overide app it goes all grey?
or the other way round?
By roozor at 2007-07-24
Set to performance
set to quality :(
