Hey guys,
I have a Pioneer KRL-32V TV with a Toshiba EP-35 HD-DVD player and a PS3 hooked up to it. Naturally, all through HDMI. Recently though (last couple of weeks), I've been getting an intermittent problem.
As people with Pioneer LCD's and Plasma's will know, when you've got them hooked up via HDMI, you get a little purple box in the top right hand corner of the screen when you turn your tv on, and when you fire up your PS3 or any HDMI device.
Now, I've had my TV since May and it's been great; cannot fault the picture or the sound I might add, but over the last couple of weeks or so, that little purple box shows up intermittently when I'm watching a DVD rip on the PS3's hard drive, an HD-DVD (tonight it happened a few times), and, annoyingly, it happened right at the end credits of Red Cliff (brilliant film guys by the way)
This problem started happening when I watched a non legit copy of Terminator Salvation on the PS3's hard drive at pretty much the exact same spot oddly enough. Could this be relevant?
I've spoken with my local Sevenoaks about this and they let me borrow a premium HDMI lead to test out for a couple of weeks, and it hasn't done it, apart from tonight when the end credits of Red Cliff appeared.
My HD-DVD player still has the standard HDMI cable that came with it, and it was showing up a good 6 or 7 times at randomly in the movie I was watching.
I've been thinking logically about this problem, and although it seems that the HDMI cable is to blame, the component that is common between my PS3 and HD-DVD player is the TV. Could it be the TV?
Also, because our flat is very compact, we have a kitchenette, and the washing machine is about a metre away from the TV, PS3 etc, and that bugger shakes everything for a couple of minutes every load (we do 2 loads a week). So, I've resorted to physically moving my PS3 into the next room before my gf
wacks a loads in, but the TV remains in our living room.
Could the vibrations be causing this? Might the HDMI cable be getting worn out as I disconnect it atleast once a week?
Could it be the PS3's firmware doing this, but then why does it happen with my HD-DVD player? Could it be a pain in the arse PS3 virus interfering with the HDMI signal? Any ideas?
Sevenoaks have said if the problem persists, they'll send a couple of technicians out, but does anyone know what on earth might be causing this intermittent problem?
Thanks
Thanks
