- 9 Jun 2006
Hi guys,
I've been having a very odd problem with the Internet the past couple of days. For no apparent reason whatsoever, I can not access any WWW page. This can happen at any time. However all my other applications that access the Internet work as normal. It's as if my HTTP traffic has been blocked, and the only way I can fix it is by rebooting the computer.
I've tried to fix it by typing "ipconfig /renew" in command prompt and I have checked I have an IP and a default gateway IP. I can ping sites successfully. I run the Windows Vista network diagnostic tool and it reports nothing is wrong and suggests I just restart my network adapter, which doesn't solve anything.
I'm completely baffled as to why this is happening. Only thing I can think of is that I purchased Zonealarm Pro a couple of days ago, and this may be causing the problem but I have tried shutting down Zonealarm when I do lose connectivity and that doesn't resolve anything. I have also tried multiple browsers. At the time of installing Zonealarm, I also installed a load of Vista updates, which also prompted me to reinstall the service pack even though it was already installed.
Any help would be appreciated
Restarting every hour or so is not fun
edit - Running Vista 64 bit.
edit2 - Gah, just realised this could have gone in the Network sub-forum
But is a Windows issue!
