- 9 Dec 2003
- birmingham
ive changed my fans out on my radiator for new ones two 120mm for silverstone FQ121 in a push,pull config
and 3x Sivlerstone 180m AP Series AP182 on the bottom of the system
all connected to a lamptron FC5 on boot the the two rad fans connected via a Y lead are at 1650rpm then after some of been on the rpm falls on the display was gaming for 30mins the rpm showed 0rpm on the LCD
but the fans still working, also if i turn all three new 180mm on at the same time the LCD goes off but the fans still power up & down via the controller
has the lamptron FC5 got a problem now ive had it since 2010 ish ??
anyone got any ideas
Thanks
but the fans still working, also if i turn all three new 180mm on at the same time the LCD goes off but the fans still power up & down via the controllerhas the lamptron FC5 got a problem now ive had it since 2010 ish ??
Thanks
