Hey everyone,
Yesterday I manually over-clocked my i5 3570k to 4.2 ghz using the turbo multipliers (voltage set to normal with a negative offset of 0.45).
I ran prime for over 3 hours and it was fine, also used intel burn test and had no problems.
I have been encountering 2 wierd issues though, which I assume are related since they started yesterday.
1. Windows 7 gadgets stop working, probably about once every hour or so (gadgets used: coretemp, all CPU meter, and network meter).
2. Sometimes the screen will go black, but will come back on if I move the mouse (I have checked power saving settings etc.).
Could these be related to the overclocking, or do you think it is a coincidence?
Thanks
Thanks
. This isn't bad considering my stock VID is 1.1950V.
