Odd LAN access problem
11 Oct 2006
Wiltshire
This could get a bit lengthy to describe so please bear with me.
Topology:
Downstairs: TP-Link BE550 router and two laptops (W10), two wired links to upstairs switch - one wired to router, the other available for laptop.
Upstairs: Netgear MS510TX switch with links to downstairs, PC2 (W11) and link to QNAP switch. QNAP switch has PC1 (W10), printer and three Asustor NAS.
The laptops and PCs are on DHCP; the printer and NASs are on DHCP reserved addresses.
If either laptop is wireless or wired to the MS510TX switch then it can see all the other devices. If it is wired to the router then it cannot see the NAS although it can still see PC1 and the printer on the same switch. The laptop wired to the router can also not been seen by PC1 & PC2 although it's okay when on wireless.
By 'see' I mean the device is not visible in Windows Explorer and a shared folder can't be mapped as a drive although ping by name and IP address both resolve correctly.
So just what is going on here? Why is the router failing to route across its Ethernet switch but okay with wireless?
I've re-instated the previous Asus router to confirm it's not doing the same as all devices are visible from a laptop wired to it.
It sounds a bit like the TP-Link is blocking broadcast traffic across it's switch ports.
You said "two wired links to upstairs switch" - What lagging have you set up for this as I wouldn't imagine a consumer TP-Link would like that setup much if at all. Also, what lagging is there at the Netgear switch end?
Only one of the wired links goes to the router. The other connects a laptop directly to the Netgear switch. When I had the opportunity to run some Cat5 from the hall to my work room, I naturally ran a spare. We also ran a cable from dining room to hall so that one can either be cabled to the router or jumpered to the spare.
That Netgear is a smart switch right? Is it trying to use it's own set of address that's different from the ones by the router and why the two aren't talking? The devices connecting via WiFi which isn't controlled by your Netgear or QNAP, so that might be why it's not impacted and can see devices still.
Yes, the Netgear is 'smart' but has nothing configured and the route for wireless is the same as for wired - through the router. And the problem is specific to the TP-Link router as the Asus I took out worked as expected.
What is your network set to? Public or private? If you’ve swapped router the pc will see it as a new network and may have assigned public which would stop network discovery.
Any filtering at all on the QNAP or Netgear switches? Is everything on the same VLAN?
The QNAP is dumb and there's nothing configured on the Netgear. No VLANs visible here.
Network discovery did stop on both laptops and was restarted as private.
