- 14 Dec 2005
- Dublin
Decided to give my pc case a clean out, as i've done numerous times before. A Chieftec case, so I remove the drive cage that has my Maxtor 6B200M0 200 gig sata drive and my old WD Ide drive in it, set it aside and clean the case out.
I put everything back together, power on....Sata bios thingy doesn't see the Maxtor. It's my main drive with 200 gigs worth of stuff I really don't want to lose
Running an AsRock Dual board with the Maxtor on one of the standard Sata 1 ports. Pc wont boot at all If i try the drive on the Sata 2 port. Not sure what that's about..anyway..
Try the usual stuff, different sata ports, cables, power leads, minimal hardware config, bios reset, you name it. No go on the Asrock board.
Pull out my old Abit NF7-S board, and lo and behold, the Maxtor is picked up. PowerMax doesnt seem to work, as it can't detect any drive attatched to the machine, but that could possibly be an incompatability with the controller on that board? ( I heard the maxtor software can be a pain in this regard )
Windows XP on that machine won't see the drive either. Nothing in Disk Management.
The drive sounds healthy...spins up and keeps whirring along happily like usual. No clicking or clunking or anything scary.
Occasionally the Bios *won't* pick up the drive, forcing me to do a reboot. Occasionally it incorrectly reports the model name of the drive as being a "Maxtou" And occasionally also misreports the drive capacity as being around 130-140 gigs in total.
Seeing as that's happening, and the drive mechanics themselves sound fine, I'm assuming this might be a drive firmware/circuit board issue?
Has anyone experienced anything like this? I'm nearly 100% certain the drive couldn't have suffered any electrostatic damage. And it was also fan cooled for the entire year and 3 months that i've had it.
I really want to get my data off the drive
Is there anything I can do? I was briefly reading threads about people having to flash their Maxtor firmware due to incompatabilities with NForce 4 boards, and am wondering if doing something like this to my drive might be a cure?
I'll appreciate any suggestions that get thrown at me
a firmware update seems to have sorted it
